RC motor fan for ecx amp mt?
I never needed one. And I've run up to a 22T pinion on 7 inch tires. But I also was respectful of giving it a break. I was more worried about catching my ESC on fire even tho it has a fan lolol# infrared temp gun
Yeah, I'm probably just going to get it anyways because it does help, and it probably will improve performance a little. Its pretty cheap too only like $12.99
Did you ever get this and do you have any measured performance increases like lower motor temps? Looking into getting something like this for myself since my motor is very hot to the touch after running it hard. Doesn't help that it's 90+ degrees outside lol.
Still haven't gotten one, i think with the stock rear motor skid plate, it might not fit, i could just try and see. If it doesn't work then just get a rear tbone racing bumper and remove the motor cover because the rear bumper would allow you to remove the motor cover.
You only need it if you are hitting 170 f or more. If you can touch it and hold your finger on it for 2 seconds or more you are OK. If you are getting hot put a smaller pinion on it to gear down and drop temps overall, that will work better than any fan.
