Replacing the servo ecx torment 4wd
Dowhat
I’d like to upgrade the stock servo on the torment 4wd. It seems like it should be pretty straightforward but the screw holding in the servo body on the medial side is partially blocked by a piece of plastic. How do I access that screw?
If you loosen the receiver plate/antenna mount (two screws on bottom of chassis), the servo should pull right out of chassis.
