RPM replacement bell crank for 2WD Torment
MikeG
Hi guys,
I purchased the RPM bell crank to upgrade the stock bell crank that comes with the Torment. My problem is I bought this last fall and started it but never finished it, now I have it all ready to go and I'm missing some hardware. I was hoping someone could help me out with what parts I need to buy to get this new bell crank attached to the body.
I have the new bell crank assembled and partially attached but I can't find the screw to attach the second part to the body (see image below)
Can anyone help with what hardware I'm missing to get this attached? I'm assuming its something that came with the original truck so if I could get a part number or any help would be much appreciated.
That part is your idler arm, it bolts on through your skid plate into your chassis.I will post a picture of mine.
My setup is hot racing ( I like the servo saver) but it goes on the same way.
No it's just a long bolt and nut, it passes through the skid plate into your bellcrank and into your chassis
