Servo
Shagz
Watervliet, MI
So I'm very new and my truck pulls to the left and I have adjusted the controller to compensate but I was wondering if there could be another problem/fix to the actual truck
I assume by that you mean you adjusted the trim on the remote? Did that straighten the front wheels? Are you trimmed all the way to one side? If so, you may need to remove the servo horn, center it up and then reinstall. It's a plastic servo horn on a plastic geared servo ( if stock) so it's not out of the question to strip or jump teeth.
You may be able to shorten or lengthen one of the links in the steering assembly (not sure what the torment's steering looks like). But usually the "problem" is that the servo horn is a notch over from where it should be. That said, if you can trim it out it's not a problem. The servo should have more reach than the linkage allows anyway, so trimming it a bit one way or the other shouldn't matter.
Edit: X beat me to the punch
