truckstuff
i have 1/10 ECX Ruckus i locked the slipper down as much as possible, the top shaft is spinning but the wheels are not so the problem must be in the gearbox somewhere, the problem with that is i got the new gear set and replaced all the gears even the ones inside the diff, off the ground with no load works fine on the ground its slow and seems like the slipper is slipping, but the slipper is not slipping what could possibly cause this?
