tastyville
So I stripped out my differential [GALLERY=media, 443]Stripped differential by tastyville posted Jun 21, 2018 at 9:27 PM[/GALLERY]No, it's not the slipper clutch or the metal gears inside or the spur or pinion gears. Inside the transmission case were about a hundred metal shavings [GALLERY=media, 442]Stripped differential 2 by tastyville posted Jun 21, 2018 at 9:27 PM[/GALLERY]
I bought my truck used. I had run it about a dozen times before this happened. I'd never oiled anything. I got a few questions:
- Is this a common failure for ECX AMPs?
- I was suspicious of the transmission case at first. Is the gear case prone to failure like twisting or crushing to cause rubbing on gears?
- Would it be worth replacing the stock gears with a metal set?
- If the metal set is prone to failure, should I just replace with a stock set and try to seal the trans case?
- Also, does anyone have any aftermarket recommendations?
