Temper ESC/RX
poiko
Hi guys, I blew up something on ESC/RX unit on my Temper Gen2 and I would like to upgrade it with either some other ESC/RX kit or with a separated ESC and RX units. I would like to keep my original transmitter ECX13008 as I do not want to invest more money to a new one. I went through ESC units, but I'm not sure, which one will be compatible to the transmitter. In older posts I found info about V4, but I'm not sure, if it is the protocol or if the V4 stands for something else. If it is the protocol, do I understand correctly, that I need to stick to ECX's ESCs only? If not, which protocol is used for communication between ECX13008 and some ESCs from other manufacturers?
Thank you
