Torment 1/10 2WD: What washer is being used with the slipper clutch and spur gear?
bobmcgill
I am missing a washer.
On the parts diagram for the spur gear/slipper clutch assembly, starting from the right there is a bearing labeled #15, then a washer with label #36, and then the start of the slipper clutch labeled #34.
My problem is that the washer is labeled #36, which is the Transmission Drive Shaft that has no washer.
Is that washer 5x7x0.5mm? I will need to find a replacement.
https://www.horizonhobby.com/pdf/ECX03006_Manual_EN.pdf
Thanks!
