Wobbel in my front tires
Maarten
Belgium
Yesterday I drove my circuit. All went normal, but when I went into reverse I noticed that my car was jigeling around because of my front tires were so "loose". Is it cause of the standerd servo can't handle the wheels? If so (or not), how can I fix this ?
With my Torment, that was because of the servo saver. If the Circuit uses the same one, that's probably the issue.
Servo saver is the issue in reverse. Rpm Servo saver Eliminator will cure the issue but you have to have a metal geared servo or you will kill i the servo on the first crash
I never cured it completely for me. Though it did help a bit. There's just so must slop in the front end of these RCs.
