Wobble when driving in Reverse
Badgerman45
I have been working on controlled steering with my AMP Crush which I just got recently. I noticed today that when I backup for any great distance, the front end wobbles significantly. Is this normal? Can the wobble damage the truck? Thanks.
Could be loose steering/steering components could use some tightening, servo saver could be a little soft
Yup, lots of slop in all of the stock steering components. Start with the RPM servo saver eliminator and a metal geared servo.
Yep the wobble is normal, wont hurt the truck, there is a trick you can try before you upgrade to the RPM servo saver eliminator, put a thin zip tie around the metal spring on the servo saver, pull as tight as you can get it. If you do use the RPM set up, use bearings instead of the delron bushings in the set up
Install the RPM or Hot Racing servo saver. Also change out the the front links to Teaxxas adjustable links and your wobble will be gone.
