My opinion is the add resistance will only slow you down and burn up batteries faster.
I find that hard to believe that thick ass oil will not add considerable resistance. Show me some proof otherwise. Then I will believe it. Whether the resistance is split between 1or 4 wheels. It still adds up to more than no oil
Do you have pics of the procedure?I sealed it up in about 30 minutes. A couple Of o rings and a step drill. I have run through about 4 battery now with no leaks as if yet
Your right 10k is to thin. its just what I had laying around. But now the seal up seems to be successful at this point. I will go get some thicker stuff.
It would probably be fine for the diff case but not on the diff outdrives.Rtv silicone?
